TwinTurbo.NET: Nissan 300ZX forum - Removing tack welds on radiator support
Subject Removing tack welds on radiator support
Posted by gbhrps on May 06, 2007 at 6:56 PM
  This message has been viewed 479 times.
In Reply To Removing tack welds on radiator support posted by s3trios on May 06, 2007 at 05:31 PM
Message Traditionally you use a centre punch in the middle of each spot weld, then drill the spot welds out. Then you use an air chisel to separate the sheets of metal to remove the panel. Straighten the edges of the panel where the old section was removed, put in the new panel and mig weld and fill each spot weld holes. Grind down any welds that are overfilled and prime and repaint the area. And, if anyone has an idea why this font size changed, I would appreciate a reply, because I'm not sure how it happened.
